Hi Folks,
I recently got a 1991 Argo 8x8 Magnum - its in great shape and is well maintained. However, one issue that has arisen is an intermittent starter problem - it usually starts fine but on some occasions all I hear is the starter motor spinning but engine is not cranking - battery power is good - brake blower is on - but the engine doesn't crank. This past weekend - it only started a couple of times but usually just got the starter motor spinning with no engine crank.
Any ideas? Is this is a solenoid issue? Starter clutch (if it has one)?
As well, is there a way to pull start the Kohler engine?
Thanks in advance,
Joey
