Hello We are replacing the front left axle right of our mkxll scrambler. Luckily the machine came with the parts manual and we found 6x6 world!
anyway the seal we took off ( usa 11141 c/r ) was easily found at the tractor store and auto part store but it is different. The one we took off the machine has a steel back on it where the new one has solid front also but the back is empty?? Two stores said this is the right part number for what we showed them. It almost looks like a steel ring was pressed into the seal.? The parts diagram just lists it as a seal.
any ideas??
FYI-- replaced a few chains with # 40 roller chain at Fleet Scrounged wheels and two tires. Purchased four new carlisle . replaced the pulse pump and fuel line. put a fuel bulb in the line to help it start. A replacement axle is being machined at my friends farm. He had earlier drilled the holes for the six adapter plates.
The axle is on and after some adjustments with fuel we got it running again. So I drove it around the yard and got it to where it will probably spend the winter. Broke another chain but we have extra brand new chain and links on hand.
We have a video of us driving it but of course I can't get it loaded yet.
The big bearing on the axle was the toughest task. Had to make a tool and precision assembly ( difficult for me at best )
