UHMWPE
Results 1 to 7 of 7
Thread: UHMWPE
    Black Country, England
    715
    UHMWPE
    Anyone know if there's a way to identify UHMWPE from other plastics? If you were given the run of a store of offcuts is there any quick / simple way of identifying the above?
    A mate of mine does factory clearance and has a multitude of bar ends, but what are they ? Some have colour coding marked on the ends but this means nothing to me.
    Any ideas men?
    Cheers
    Cayley, Alberta
    472
    Probably could weigh them and measure the volume. Not the best solution, but given that uhmw is quite a bit more dense than the others....
    715
    Quote Originally Posted by Beeman View Post
    Yeah, I had thought of that. I know it's denser than other Polyethylenes but will the weight per c/i be much different to say Nylon (or other plastics)?
    Cayley, Alberta
    472
    Not sure. There might be a chart out there in a google land that might have the two densities on there. Other than that, i guess it'd come down to doing some trails.. like a scratch test or a burn test.
    715
    Already googled identifying it and just came up with specs and chemical analysis, and I'm certainly no chemist. Bit of a bummer really as I may have a cheap source for it.
    Mar 2013
    San Francisco Bay Area
    328
    One of the mechanical guys from a place I used to consult had a great plastic identifying chart which I copied and I'm sure have save somewhere. It had a flow chart that covered the feel, flame test reaction, density, and other things that at the end helped you determine what type of plastic sample you had. I realize this does you no good, other than to know the information you want is out there and if you dig enough you can find it.
    715
    Quote Originally Posted by phabib View Post
    Never thought of googling a flow chart. You're a star, found a chart and can now do a rough ID on site to make sure it PE then a further test at home to make sure it's uhmw.
    Thanks for that buddy
