Brand new 2021 Argo 6x6
Results 1 to 10 of 13
Thread: Brand new 2021 Argo 6x6
    Need help with my brand new Argo , it’s a 2021 Argo 6x6 vanguard with 2 hours on it
    The issue is when driving it looses power and wants to bog and will only top out at 27 where when I first got it couple months ago would be go full power and get up to around 47.
    Again this is a brand new machine with 2 hours on it .
    Any help is very appreciated!
    Last edited by Moderator Bob; 01-14-2022 at 04:52 PM. Reason: Moved thread into Argo section.
    2,639
    47 m.p.h. ....sounds like a dragster , never heard of one that fast .is it a racer ?? j.b.
    Feb 2020
    Fort Erie, Ontario
    45
    I'm guessing that's in Kilometers per hour= about 28 or so mph.
    Perhaps you simply pressed the km/mph button and switched it, try to find the km setting and see if it goes back near where you were.
    Correct I’m in Canada
    It is in km , I’m in Canada
    Just had it out it’s runs good with good power up to 38 km but when at idle it wants to quit and sometimes it will idle fine but when going between gears wants to quit as well sometime s
    Aug 2020
    PGH , PA
    85
    Is this a carb model ? You may have bad fuel in it
    Dec 2020
    Upstate NY
    121
    Run a bottle of stabil quick engine fix threw it. Made my 2021 6x6 run great. Was surging and idling sporadic. That fixed it.
    Nov 2020
    201
    You may have gotten some water in the fuel. Very common and easy to happen. I find the same symtoms in snowblowers.It may work itself through but if it continues you may have to drain the tank, carb, if equipped, fuel lines etc. The engines seem to run better on a higher octain rated fuel. Most of them have less or no ethanol. Check your fuel source, in my case,gas can, for contaminants.
Tags for this Thread
