I know we have discussed this before. Are you still using the original braided ground strap? I’ve had several fail in the crimped ends. Have you used a jumper battery when it acts up? The added...
I should have mentioned I have the 27 hp Kawasaki. The solenoid is on the starter itself. The solenoid clicks but doesn’t engage to the flywheel. I will triple check the wiring. Such an intermittent...
Since you provided a list of items you have done, I believe you have either a bad starter solenoid or there is still an issue with the wiring such as a loose connection or an internal break in a...
What engine do you have? When you say it clicks but wont engage, where is the click coming from? Is the solenoid clicking and the starter motor not spinning? Or is the starter not engaging the ring...
Try checking the amp draw the next time it happens. If it is real high at the starter try turning the engine over by hand, then try the key again. If you have little to no amp draw you know the...
Here is an Amphicat dealer promotional video. You can read a little more about the video on the forums in this thread: Amphicat 6x6 ATV Promotional Video
Here are some brochures from Mobility Unlimited Inc. out of Auburn Heights Michigan about their Amphicat 6x6 ATV. This amphibious ATV had a lot of options:
(click on the thumbnails for larger images)
Here is a cool article written by Tom Robinson about the Amphicat amphibious ATV:
Service bulletins Vol II No 1 & No 5:
A downloadable PDF of Amphicat's warranty information bulletin from Mobility Unlimited to their dealers:
A bulletin informing Amphicat dealers that Mobility Unlimited, Inc. had been sold to Magna American Corporation:
A copy of Cat Talk Newsletter:
An Amphicat dealer's price list:
Two random bulletins:
Below is a brochure on the Amphicat Amphi-Kitty also manufactured by Mobility Unlimited Inc. This mini-bike was powered by a 5hp motor with large flotation tires. While it wasn't amphibious, due to the large tires it would float.
Advertisement for Amphicat in July 1969 edition of Snow Sports magazine
Article on the Amphicat in Wisconsin Motor News section
An article on ABS plastic bodies used on the Amphicat
Dri-Slide lubricant advertisement using the Amphicat
An Amphicat Parts Manual can be found in the Articles section of the site or by following this link: Amphicat Parts Manual
I know we have discussed this before. Are you...
msafi65 03-28-2024, 07:15 PM
