This is a PDF of the Max II, Max IV and Buffalo Truck Operators Manual. This is a 111 page manual that covers everything from safety to operation and maintenance of your amphibious Max ATV from Recreatives Industries.
Max Operators Manual
This is a 12 page parts list for a Max IV with exploded views detailing every component of this ATV.
Max IV Exploded Parts List
This PDF details the installation of a Warn winch on a Max II 6x6 ATV
Max II Winch Installation
This PDF shows you how to install Max Tracks on your Recreative Industries 6x6 ATV
Max Track Installation Manual
The following PDFs are from a drive train service and repair manual for Max IV 6x6 ATVs:
Bearing Replacement
Max IV Bearing Replacement
Axle Replacement
Max IV Axle Replacement
Max IV Front Axle Replacement
(for serial numbers 19417 and later and all snap-ring style axle replacements)
Max IV Center Axle Replacement
Max IV Rear Axle Replacement
(for serial numbers 19089 and later and all rear splined axle replacements)
Sprocket Replacement
Max IV Sprocket Replacement
(for non-snap ring style sprockets)
Max IV Front Sprocket Assembly Replacement
(for serial numbers 19417 and later and all snap-ring style front sprocket replacements)
Max IV Center Sprocket Assembly Replacement
(for serial numbers 19417 and later and all snap-ring style center sprocket replacements)
Max IV Rear Sprocket Assembly Replacement
(for serial numbers 19089 and later and all rear splined sprocket replacements)
Wiring Diagrams
Buffalo Truck with Kohler Command 20HP
(Harness used in production as of serial number 11998)
Max II Briggs & Stratton and Tecumseh
(Harness used in production prior to serial number 12275)
(Harness used in production from serial number 12275-16900)
(Harness used in production as of serial number 16900)
Max II Briggs & Stratton and Kohler
(Harness used in production as of serial number 20060)
Max IV Kohler
(Harness used in production prior to serial number 11998)
Max IV Briggs & Stratton and Tecumseh
(Harness used in production prior to serial number 12286)
Max IV Kohler
Max IV Kohler
(Harness used in production from serial number 11998-12791)
Max IV Kawasaki
(Harness used in production as of serial number 19007)
Frame Reinforcement Kit
Max IV Frame Reinforcement
Max IV Frame Reinforcement Kit Dimensions
Heated Throttle Cable Installation
Max IV Heated Throttle Cable
5 Pin to 7 Pin Ignition Key-Switch Conversion
Max Five Pin to Seven Pin Ignition Switch Conversion
Cooling fan runs.
Cooling fan runs.
Jonthecarver 05-31-2023, 08:38 PM
