+ Reply to Thread
Results 1 to 9 of 9
Thread: How to patch this???
  1. #1
    waterman28 is offline Registered Rider waterman28 is on a distinguished road
    Join Date
    May 2012
    Posts
    4
    Any ideas on what and how to patch this? The body is made of plastic, polyethylene I think. there was some fiberglass patches on it but they were not stuck to the plastic very well and pulled right off. the plastic seems very slick. So I am hoping someone out there has had experience with repairing this type of plastic.
    Thanks
    [IMG][/IMG]
  2. #2
    jpswift1's Avatar
    jpswift1 is offline 6x6 World Sponsor jpswift1 is on a distinguished road
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    5,292
    The Sierra Trail Boss body is made of HDPE (poly) plastic and is very repairable. Fiberglass won't work at all on it. Try this:
    http://www.6x6world.com/forums/conte...dy-repair.html
    Then use the search feature on the site and you'll come up with lots of great ideas. Good luck with it!
  3. #3
    teeko is offline Sophomore Slider teeko is on a distinguished road
    Join Date
    Feb 2011
    Location
    Burlington, Ontario
    Posts
    74
    If its HDPE you should be able to plastic weld it. Harbor Freight sells plastic welders at a reasonable cost. I have a few cracks in mine as well but I think mine is made of high impact plastic. I tried welding it and it didn't work. I also tried the heat gun to remove oxidation and that didn't work either. I am curiouos to see what others say. My machine is a 1970 Argo.
  4. #4
    brushcutter is offline Master Mudder brushcutter is on a distinguished road
    Join Date
    Nov 2007
    Location
    West Central Louisiana near Toledo Bend Reservoir
    Posts
    910
    Read Jims thread, looks like the stuff he used is a good candidate for repairing your tub. post #7 MaxII Bigfoot/Tall tub
  5. #5
    thebuggyman1's Avatar
    thebuggyman1 is offline Jim Taylor thebuggyman1 is on a distinguished road
    Join Date
    Nov 2009
    Location
    Charlotte, Mi 42.605855,-84.799466
    Posts
    1,955
    Quote Originally Posted by brushcutter View Post
    With the epoxy, and also with plastic welding....the finished strength is dependant on how well you prep the surface.
    When plastic welding you need to scrape the surface conamination off to give the weld good plastic to adhere to.
    With the epoxy, the mfgr published adhesion strength with different surface prep methods....see thier web site.
    Personally, whether welding or using epoxy, I'd fix the crack, then put another patch over the top of it for extra strength.
    "A child of five would understand this. Send someone to fetch a child of five." Groucho Marx
    “There are two theories to arguing with a woman. Neither works.” ― Will Rogers.
  6. #6
    TalSet's Avatar
    TalSet is offline 6x6 World Sponsor TalSet is on a distinguished road
    Join Date
    Oct 2009
    Location
    Rock Tavern,New York
    Posts
    126
    G/flex Epoxy Kayak Challenge - YouTube i had a six inch gash in the side of my max IV due to the primary clutch sliding over while it was spinning and cutting the tub. used this product over three years ago, and still have no problems with the repair. i used some small aluminum strips to hold the gash together on the inside, pop rivited on, then i put some metal window screen on the outside , and covered that with this product. worked great.
  7. #7
    Join Date
    May 2012
    Posts
    4
    Thanks for all the great replies. I am going to get the motor installed and than get after the cracks. no since in fixing cracks if i cant get it to the mud and water.
  8. #8
    carbidegrinder is offline Registered Rider carbidegrinder is on a distinguished road
    Join Date
    Apr 2012
    Location
    southern maine
    Posts
    18
    find some one who has a plastic welder. they are used on those big orange barrells that you see near road work
  9. #9
    Join Date
    May 2012
    Posts
    4
    Quote Originally Posted by carbidegrinder View Post
    Maybe I will just put my tires wheels and motor in one of those barrels
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
