Well I've been searching for a long time on info and the patent located in threads here have helped me more fully understand the Hagen transmission.
TRANSMISSION SYSTEM
Now what I'm able to determine thus far from reading and testing, is the hydraulic control component of the transmissions function is entirely independent of the gears and function within the case. Two systems combined to make one functioning transmission.
Also the PTO input be it CW or CCW does not matter as you just swap upper and lower hydraulic hoses on each side to make the controls function as desired.
That the Annular piston that controls the clutches can be adjusted for internal clearances and lets say should be 0.039"-0.045" clearance from what I can tell from testing.
There are two return springs for each clutch piston to keep the unit in the neutral position when controls released.
What I'm not able to figure out except for a guess, based on one image of a yellow ridge runners engine cover, is that it used ATF for fluid in the transmission. I saw a NAPA ATF bottle in a picture of a Ridge runner one day and subsequently felt that's what it uses.
Does anyone know what fluid the transmission utilizes?
