Ya' know that was the only thing I did not like about Sandcassle's Hustler. The early model shifters with cables were not so good. If yours is like Sandcassle's, then you do not have the spring assisted shift like the later model ones. Also, Sandcassle's did not have the diamond shifter hold-downs like mine. I would be very tempted if I were you to see if you could convert yours to the later model shifter set-up. It would not be too hard, and at 50 bucks per shift cable, it could save you some money in the long run.
NOTE: While those early split shifter Hustler's have an inferior shifting set-up, what is weird to me is that the drive chain tensioners are far superior than the later model like mine. I wonder why they downgraded in the later models??
EDIT: I don't think Kestian is doing anything wrong or his T-20 is malfunctioning....Sandcassle's Hustler is PRISTINE and his was doing the same thing. IMO, it is a combination of no spring assist and lack of diamond shifter hold downs. It just allows too many variables for things to go slightly wrong when shifting.
