Got my axle out but had to pull with cage still on with outer two bearings still in place they won't budge.I am going to borrow a bearing puller to pull the middle one but to get the one out by the wheel will have to send it to a machine shop if its seized on like the middle one.I believe this is going to be a gargantuan task as the third bearing increases the difficulty even getting at the outer two but the high side is.....the bearings are shot.......light grinding when turning by hand though no play.I was surprised that the inner bearing is smaller I believe it is the 62 mm.
