Amphibioius Atvs Logo
Go Back   6x6 World > 6x6 ATVs > Max ATVs
Max ATVs Forum for discussing all Max 6x6 Atvs from Recreative Industries including the Max II, Max IV and the Buffalo truck.
Reply
  #1 (permalink)
Old 10-05-2008, 02:04 PM
katoom08 katoom08 is offline
Registered Rider
katoom08 is on a distinguished road
Shifting Gears in a Max II
Hi. I was playing with the max in the yard today trying to get used to the sticks. It was fun but it sure tears up the yard. I seem to be having trouble getting into Forward and reverse from neutral. It seems as if the clutches never stop spinning so when I try to shift it wants to grind. Am I not useing enough finess? or is there a trick I need to know? Is the torque converter need adjustment? I feel like if this continues I will do some damage.
Arlen
  #2 (permalink)
Old 10-05-2008, 02:09 PM
rdr's Avatar
rdr rdr is offline
6x6 World Sponsor
rdr is on a distinguished road
Send a message via Yahoo to rdr
Quote:
Arlen
all t20 do: it some times it shifts easy some times it a dog .
__________________
1999 max 2 18 b&s 22 tires custom winsheild rear rack and deer stand . new max iv 23 k 26 i/n tires brown . ht cable mile marker 2500 winch. if it don't float with out you getting wet . don't bring it !!!!
  #3 (permalink)
Old 10-05-2008, 03:05 PM
Registered Rider
Thanks RDR !
I was afraid I was doing damage. It seems like the belt should stop turning so the gears would mesh.
  #4 (permalink)
Old 10-05-2008, 03:41 PM
racerone3's Avatar
racerone3 racerone3 is offline
6x6 World Sponsor
racerone3 is on a distinguished road
i don't even have an operational machine with a t-20 yet, but mike told me a litle trick a few weeks back when i was running his max 2. use 1 hand to slap both laterals back while using the other to shift. you basically want the laterals to be bouncing back and forth while trying to shift. this will allow the gears to keep turning and get lined up, but slow the drums down enough that they find their happy place at a lower speed and with a lot less grinding
__________________
"momentum is your friend"
  #5 (permalink)
Old 10-05-2008, 04:08 PM
rdr's Avatar
rdr rdr is offline
6x6 World Sponsor
Quote:
thanks race i should have gone into more detel . robbie
__________________
  #6 (permalink)
Old 10-05-2008, 05:58 PM
Eldon Eldon is offline
Registered Rider
Eldon is on a distinguished road
When I got my Max II I was discouraged about the shifting until I received a few tips.My machine only had 28 hours on it and I was told until fully broke in it would be cumbersome.Beyond that try not to shift immediately after turn but rather when the machine has been going straight for a foot or so,when shifting to forward pull both sticks back with one hand,maybe a rev or two on the engine then as pushing the shift lever down release the sticks to spring forward and it should smoothly drop in forward.When shifting to reverse,pull both sticks back a fair distance and while holding them back put shift lever in reverse.Sometimes when shifting into either forward or reverse it seems necessary to give the engine a couple of revs and going in reverse seems easier if while holding levers back,pull back slightly more on one than the other,I pull back more on the right than the left,seems to work for me.The T-20 is what it is,it seems it is we operators that have to get synchronized a little.
Eldon
  #7 (permalink)
Old 10-05-2008, 09:00 PM
Registered Rider
Thanks for the advice Race and Eldon. I will just have to force myself to practice more !!
Arlen
  #8 (permalink)
Old 10-05-2008, 11:17 PM
Hey_Dan78's Avatar
Hey_Dan78 Hey_Dan78 is offline
Sophomore Slider
Location: Tonawanda NY (Just across the street from buffalo)
Hey_Dan78 is on a distinguished road
Shifting
Check to see if the engine clutch is open all the way when the engine is idling. If not there may be a problem with the clutch or the engine idle speed may be too high.
  #9 (permalink)
Old 10-10-2008, 07:11 PM
carrant carrant is offline
Registered Rider
carrant is on a distinguished road
In my RI Buffalo I had a heckuva time shifting until I installed the "easy shift" kit from Richard's Relics.
After the installing shift kit, shifting went from "a battle" to "hot knife through butter"...
For the Buffalo, I believe the kit was $65.
Welcome to Richard's Relics Parts for ATV's
chris
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
