sidewinder drive setup
Results 1 to 4 of 4
Thread: sidewinder drive setup
    Nov 2009
    South Jersey
    25
    Well Guys I got my steering cable tried to move and found out my drive clutches slip If you dont know on the sidewinders its similar to a scrambler(not hydrualic) but mine is all mechanical(steering wheel) as the steering cable move it moves a ramp that pushes pins to disengauge the drive clutch and push it against the brake setup for its side,What I am trying to ask is if I should ditch that setup and go for a scrambler setup or go for a t-20 setup which I know can be expensive,unless someone has a working spare sidewinder setup they want to sell??I need some options....Thanks..
    Nov 2009
    South Jersey
    25
    Any Options?
    Central NJ
    1,470
    T-20 are a good retro and so are argo's trans. both are not cheep. Both require a jackshaft to correct the gear ratio.
    the early sidewinder with the scrambler like spring loaded clutch plates require a good running surface and adaquate spring pressure. if the clutches are corroded you willl probably have to machine them smooth.
    Nov 2009
    South Jersey
    25
    Thanks Jersey,Spring pressure seems good but I did check what you are saying about the clutch plates and they are corroded I am going to machine them and see if that fixes the problem.
