homemade tracks question
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 74
Thread: homemade tracks question
    Jan 2013
    mattice, ontario, canada
    39
    I've been looking around for tracks for the better part of the year and i think i have a good idea of what works best. Open tracks with optional extentions for deep snow seem to be the best thing since sliced bread. A friend of mine got these with an 1991 argo magnum he bought a few years back. He had never used them as they ran way too rough. (not hard to figure out why, there is way too much gap between the angles) So i bought them off of him for 150$ and i bought 80 feet of steel angle matching the originals. I am modifying the existing guides and will be putting in the stock argo ones to the angles that i add. eventually i will replace all of them but my budget is limited this year. i'm cutting out the center of the belt so the tracks will run open like escargos or adairs. my question is since i am cutting out the strap in the middle i'm making the tracks 1/2 inch longer right? and in turn i should shorten them a bit? they are already a bit long. i was thinking of measuring all my tires and placing them all accordingly to run tracks then inflating them to the psi i need to run the tracks. i would then measure the total length to go around all tires with a string and adding 1 inch.
    Sa passe ou sa casse!!!!
    2,637
    martz, i made my own homemade tracks and they worked great. i am not as wise about tracks as alot of the members are, but i am not sure cutting out the center of the belt will shorten the tracks. in terms of correct length, when i did mine i let the air out of the tires, laid the tracks on the ratcheted them tight as possible. cut and attached them then air the tires. let,s see what the others have to say. johnboy va.
    Jan 2013
    39
    @johnboy what i meant is the tracks are a bit long at the moment, since im cutting out the middle im removing 1/4 inch in between the tire and the crossers so im making more room thus making the tracks "longer". your way seems like a pretty good idea i can't see why it wouldn't work well. i might just try that. No power here today so can't work in the shop but hopefully i can have one side done by wednesday
    2,637
    martz, i am curious as to how your tracks hook together. the ones i made have chain on the crossers that i pull tight on each end, then hook together with a quick link. because mine are solid rubber like your originals, i used a 4'' hinge with a pin to connect the belting after the quick links are connected. i left the belting long until i had connected the track with the quick links, then aired up the tires, then cut the belting to match up. it worked out very well. would like to see your finished product when your done. johnboy va.
    Jan 2013
    39
    they simply overlap 3 crossers over. i thought it was simple and seems to work good. im taking pictures as i go along i will post more soon
    Jan 2013
    39
    here is an idea of what it is going to look like. My steel comes in on wednesday so i will be able to add a piece in between each existing ones. it is going to take a very long time to get this done
    Oct 2010
    Wasilla, AK
    923
    Quote Originally Posted by martz694 View Post
    Aaah, you'll have fun. Look forward to seeing it!
    Oct 2010
    Wasilla, AK
    923
    your tire tread will ride on the level of the steel which will be "slightly" (the belt thickness) lower than the top of the belt. Your grousers will be driven slightly (very slightly) slower than the tread of your center tires. Your center tires will slip very little...which is works out just fine, those are the tires you want to slip. It won't be very much at all and will happen easily over open grousers. Your track belting length should be just "slightly" shorter that the distance measured around all of your tires on the tread centerline. In fact you could probably just measure around your tires (when they're flat) and make the track belting that length. That way when you air them up, it should be about right. You can always shorten it an inch or two if needed. Hopefully that gives you a starting point.
    2,637
    martz, they look really good. for anyone wanting to make a set of homebuilt tracks, that is a good design. you buy the belting, 1'' by 1'' angle probably 1/4'' thick to start. then instead of having to bend tire guides, buy some rectangle hard plastic or delrin stock and cut pieces about 4'' long. then drill a 3/8'' hole down thru the center. drill the holes in the angle so the guides are the right spaceing for the tire width and run the bolt thru the angle,then the belt, then the guide. add a lock nut and your done. both pieces of belts can be connected with a good flat hinge and a pin. the nice thing is if a guy wants a wider track , the belting and angle can be extended on the outer side of the tire for more width. johnboy va.
    Jan 2013
    39
    @buzz well thats what i was wondering if there would be a big difference in "space" in the track since i am removing the belting from in between the grousers and the tires. that was my plan for finding out the length i needed was to put all my tires on flat and measure the lentgh on each side with a string. make the tracks that long that way when i air them up they are nice and tight and i don't have too much sag.
    @johnboy i've been looking at alternatives for the guides as the argo ones are expensive and they would have to be modified on my design. As it stands i only have guides every 8 inches which worked fine when they were full belted tracks used on snow. i'm not sure it will be enough for all season driving. My angles are 3/4 by 3/4 by 1/8 thick and 14 inches wide.
