So I've got my 18 hp B&S at a speed shop getting rebuilt, told them I wanted to at least double the hp...they said it would be no problem. Can't wait to get it back and put it back in my max IV and try it out. I'll will follow up when I get it back.
fast, reliable, cheap-- pick any two. Anything is possible.
Jason
2015 Argo frontier EFI Camo. 4000lb vortex winch with synthetic rope. 3.3 trans.
~1998 Max IV (SN 14428) on 26" TRU Power tires, winch with synthetic rope, rear seat moved back 5 inches, flip top rear seat with storage underneath, 55 lb thrust trolling motor, #24 marine Battery and a bilge pump just in case.-sold
martin, been thinking about doing the same with my 16 h.p. vanguard. to rebuild to a 22 h.p. was about half the price of a new 22h.p. let us know how you make out and the cost also, thanks j.b. someone local doing it ?
I don't want to hijack your thread BUT(ha) I am wanting to do something similar. Currently my machine has a hustler 950 with a 14hp bs and I have a 18hp bs sitting on the shelf. I was wondering if the 18hp carb will work on the 14? I know putting a 16 carb on a 14 and removing the restriction in the exhaust puts the 14hp to 16hp but not sure if the 18 carb will work. I want to run the current engine(14hp) until I rebuild the 18. I hope to get 24 or more hp out of the rebuild.
So to recap, 1. Will the 18 carb work on the 14, and 2. Am I expecting to much hp out of the 18 rebuild?
Thanks Jim, just to make sure I'm tracking i should pull the main jet out of the 18 carb and put it into the 14 correct? Also I jacked up my 18 carb today while taking it apart. What I think is a pickup that is pressed into the top of the carb broke off. The 18 carb is a nikki 6100.
Yes as long as they are both the Nikki s, the 14 & 16 are the same with 16 having bigger jet.
I would have just swapped the carb and intake as a set and try it, 10 mins and your done
Hey guys, I still haven't gotten my motor back yet but it shouldn't be too much longer. I will definitely let y'all know the results when I do get it back.
