Gents, I just bought a little used, low hours Max 2 and I have some questions concerning modifications for it. It has the 16 hp Briggs engine.
1. How would chains work instead of tracks? Seems to be an easy install for the front and rear tires, proper fit and clearance would seem to be easy. Has anyone done this and if so, how well did it work?
2. Access to the engine compartment:
I’ve read about the ‘top cut out/refit method here. What about cutting across the whole top piece from right behind where the rollbar is, completely across the back allowing completely lifting off that part only undoing 7 wing nuts and disconnecting the tail lights?
Would much appreciate any and all advice and comments, thanking you all in advance for them.
