So im new here, just picked up my first 6x6, its a 96 max iv, seems to be shifting terrible and popping into neutral or not engaging all the way?? And also seems reverse only works on the left lateral, havent got a change to tear into it much but im going to unhook the linkage at diamond shifter plates and try to shift by hand and eliminate the linkage that is bent mid way in the belly pan, but anyways my main question is has anyone ever used shifter cables from like a aftermarket automatic trans shifter like b and m? Ive been pondering to use to cables to make my own split shift and eliminate manual linkage, my only concern is how much force does it actualy take to get the t20 to shift?
