Hi i have a 2008 avenger with 18" rubber tracks was wondering if can use high gear in snow (on flat even terrain) or just stick to low gear. 3.3 trans.Most write ups are about hdi's. Thanks
You should absolutely use high range on the flats especially if you have the 3.3 gear set. You have a gen 2 classic tranny and it is not an issue. You just don't want to over work your belt by using high range in the steep and deep stuff. I use high range all the time on the flat stuff in my conquest with a 3.3 gears and 22" Chanel tracks (heavy). I always carry a spare belt in all my machines as you should, but have never had one break.
Thanks for the info. Much appreciated. Im new to argos as of this year. Will be using it for cabin winter access for me and familiy. At least thats the plan. Plan to carry lots of spares.
Do either of you run tuners?
Ive set up the tires and track seemed to be going fine on dirt with no issues.
