Adding actual brakes to an old Trailboss?
Results 1 to 4 of 4
Thread: Adding actual brakes to an old Trailboss?
    Hi, I've had my trail boss for a number of years. It's been fun to run around in, and much better now that I have the right belt on the drive. Now it'll move along pretty fast (for a 6x6). One problem I have is the stopping. It's either coast to a stop, or reverse the sticks. Reversing the controls seems pretty harsh, and at times can send me off the trail (usually to the left).
    I was trying to think of a set of brakes or brake for the input shaft. I'd rather have a hand throttle, and use the current pedal for the brake. Any ideas on what might work? I was thinking of borrowing something from a snowmobile (older cable/disk brake).
    Thanks!
    Fairbanks AK
    1,457
    I have a friend that added hydraulic brakes to center axle of Max IV. I don’t have the part numbers but know he used parts from midget racer or gocart. Mechanical disc from snowmobile would be a choice to look at.
    Thanks.... at least I know it can be done. Looking at the center shaft, it looks like it'd make the most sense. I might even look at a hand brake for one stick, and a hand throttle for the other.
    It looks like the hardest part will be the bracket to hold the caliper, and finding a brake disc I can use on the shaft.
    Jun 2014
    North Eastern NC
    370
    I used these two items from eBay, made my sticks like a quad, turned 90 degrees left and right. made some hubs to hold disks. I installed them on the front axle and removed the parking brake and pedal. Made brackets to hold the calipers. the hydros work great.
    https://www.ebay.com/itm/Hydraulic-F...53.m2749.l2649
    https://www.ebay.com/itm/NEW-180MM-F...53.m2749.l2649
Tags for this Thread
