runs good again
Results 1 to 5 of 5
Thread: runs good again
    2,638
    runs good again
    was having trouble with hydro lock in my max 2's vanguard .took it to a friend who is a small engine mechanic . it just was'nt running right either . after cleaning out the carb , cleaning out the gas tank and new fuel lines ,filter and air cleaner...she purr's right along. it was worth paying a more knowledgable person than myself . ready for winter now . johnboy va.
    Dec 2018
    Muskoka, Ontario
    95
    It's a great feeling when everything is all good again
    Texas
    2,161
    John:
    Start using Startron. You can avoid these problems.
    2,638
    thanks noel ..that's a definite ! i'll check the local auto parts if that's the place to get it . i probably let the fuel lines past their good condition use too and need to make sure and use a funnel with a screen in it . i try to use non ethanol as much as possible , but is kind of scarce around here . jboy
    John glad to hear you got it all good now, as mentioned startron is a good thing, a shut off valve for extended periods of parked is also good, you can run all the gas out of the carb.
