Just picked up a Response 8x8..Noticed a little play in three wheels. Figured outer bearing..No problem..Removed the axle and the bearings seem decent no movement. It appears that the set screws filed off and the inner bearing casings were moving on the shaft and has worn the shaft on at least two of the axles. Has anyone seen this..If I replace these bearings will I have the same problem especially now that the shafts are worn. The bearings are loose on the shaft until I set the set screws. What could have caused this and how can I avoid this in the future..
Thanks
