+ Reply to Thread
Results 1 to 6 of 6
Thread: Exhaust mod to the mudd ox.
  1. #1
    smokeeter is offline Registered Rider smokeeter is on a distinguished road
    Join Date
    Nov 2010
    Location
    Ontariariario
    Posts
    15
    I was having a problem with excessive heat building up in the engine compartment, to the extent that the coupling between the hydraulics and gas engine had melted and stripped.
    I had a stainless steel manifold made that went straight out to the side of the engine compartment and mounted a stainless flow thru magnaflow muffler outboard. I wrapped some exhaust insulation on the pipe to help keep the heat down. We ended up putting a heat guard around the muffler to keep the burns to a minimum.
    Oh ya also put a ramsey winch on the beast , this one is removable and will fit in the rear receiver if needed.
    Here are a few pics of the new set up.
  2. #2
    jpswift1's Avatar
    jpswift1 is offline 6x6 World Sponsor jpswift1 is on a distinguished road
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    5,294
    Great idea! So many of these Mudd Ox owners have overheating problems, and it seems the problem was never really corrected. The way you did it is the way that it SHOULD have came from the factory. Nice work, and it looks great!
  3. #3
    Cougar's Avatar
    Cougar is offline Master Mudder Cougar is on a distinguished road
    Join Date
    Nov 2007
    Location
    Decatur,In.
    Posts
    320
    I don't have a overheating problem. I was running mine last month when it was 98 out. Cougar
    2010 Mudd-Ox 8x8
    2012 Mudd-Ox 6x6
  4. #4
    mudbug3 is offline amphib fanatic mudbug3 is on a distinguished road
    Join Date
    Jul 2007
    Location
    I live in Shreveport,,Louisiana
    Posts
    3,169
    My Mudd-Ox ran really hot in the east Texas heat when the temps were in the high 90's before I sold it . I would often have to take the engine cover off to allow the heat to escape faster if I'd been running through very thick mud for an extented period of time. I know that problem would be even worse now with the temps of 115-118 with the heat index.
    But, with this being said, I've also had the exact same problems with my new 2011,Argo Frontier. It would spit and sputter when ever the engine compartment got really hot. One time the engine temps became so hot with the hood on, that even after having the engine cut off for 20 minutes time, the engine sputtered and poped and then died when trying to climb a steep hill. I then took the hood off and waited another 20 minutes until I could drive again.
  5. #5
    chris davison is offline Master Mudder chris davison is on a distinguished road
    Join Date
    Oct 2010
    Posts
    306
    Did this new pipe solve the heat problems? Thats a great looking weld and fab job. I have to do some sanitary s/s tube welding almost every week as I work in a food processing plant. These over heating problems should have been solved at the factory especially when you consider the price of a new Mudox. Do they have the ability to install an oil cooler or extra cores to the radiator? Does your hyd oil over heat as well?
  6. #6
    Join Date
    Nov 2010
    Location
    Ontariariario
    Posts
    15
    so far the heat issues have subsided, when you combine the heat from the exhaust and the heat from the hydraulics it seemed too much for the plasitic coupler to bare (it sits right in between the previous muffler and the hydraulic pump). I don't feel I need to beef up the hydraulic cooling system, the rad and fan seem to be doing their job adequately.
    I may have to change the magna flow muffler I currently have since it's a flow thru and the machine is quite loud at the moment. If I get a bigger diameter muffler with an offset design I think all of the heat issues will be a thing of the past.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
