New Terra Tiger owner
+ Reply to Thread
Results 1 to 7 of 7
Thread: New Terra Tiger owner
  1. #1
    Hey all, I have all ready had an amazing amount of help from the good people here on this site. I will tell you that I have been an antique tractor collector for almost 10 years and have met a lot of helpfull people but nothing like what I have found here. I have the Tiger cleaned up and am starting on getting her started but I have not had any luck trying to repair the broken fuel tank. Anyone know where I could find one of them? I am also going to need the plugs for the holes in the bottom (I don't want to end up like a guy I saw a photo of on this site. There are 2 red wires coming out of the front of the JLO295E engine that I do not see mentioned on the wiring diagram can anyone tell me where they are to go? OH, thanks again Don for the manuals lastly..at least in this post, where the heck is the battery supposed to go and what battery do I need? This thing had a car battery in the rear connected with what looked like welding cables..I really don't think it is going to pull anywhere near that much juice.
    Thanks again guys
  2. #2
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    6,442
    I think Mark m. Amphiman1 and racerone are the guys on the site that know the Terra Tigers real well. They might be able to help you out with the gas tank and battery question. As far as the drain plugs go, I would recomend these units:
    Kayak Drain Plug W/ Base - Austin Kayak - Product Details
    Here is some more info on drain plugs here:
    http://www.6x6world.com/forums/gener...-clean-up.html
    I am converting all of my machines to this type of drain plug, and from what I've heard, people have very good luck with them.
  3. #3
    Join Date
    Jul 2007
    Location
    Grand Island NY (Buffalo)
    Posts
    254
    Welcome. The plugs I use for mine I get at a local marina store. There 1 inch diameter expandable rubber drain plugs for boats. They work great.
    The 2 red wires the way you described them could possibley be your alternator wires that need to go to a voltage rectifier but these wires a typically yellow. The second choice might be the wires used to ground the ignition circuit to shut the engine down.
    Fuel tank. I made my own to fit the machine the way I wanted it. It's made of aluminum in the back.
    Battery goes under the leftside of the dash but you might want to keep it in the back. It's easier acsessed there.
    Mark
  4. #4
    Terra Tiger Wiring and Carb issues
    Well guys I am a little farther on my project but just as I thought the Yellow wires to the rectifier have both been disconected and the coil wire + the black coming out of the JLO are wired to a kill switch. Does anyone have a photo they can send me of the correct wiring configuration? I see by the diagram that 2 wires come from the coil to the yellow rectifier wires but I have only 1 coil wire (+ a ground) and then I have 2 red and a black coning out of the engine. I think my best bet is to just rewire this so that I know it is all correct but right now I need 1st get her started. I think my main problem with her not starting is the carb is going to need cleaned (fuel coming out of the ventura). Like I said in an earlier post I have worked on my antique garden tractors for years but this is my 1st 2 stroke. is there a special kit I will need for the carb or can I just disasemble and clean it like I have on all of my 4 strokers? Any suggestions or things to watch for when attempting to clean this or as a first timer should I just take it to a bike shop and have it done?
    Sorry for the long post and I REALLY do appreciate the help
    Les
  5. #5
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    Hey Les, I know nothing about two strokes but I see you are referring to a wiring diagram. Did you see the ones in the literature section too? I didn't know if those might help or if those are the ones you are referring too. Here's a link:
    http://www.6x6world.com/forums/gener...o-engines.html
  6. #6
    Wiring
    Hey Mike thanks!! that really helped...I have 2 red and a black instead of the 2 yellow and a blue but at least I know where those darn red ones go now. I idn't just want to guess. I am now going to start a totall rewire..wich i could just get a new harness but Oh Well
    Thanks once again
    Les
  7. #7
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    2,604
    i can't help with the wiring... mine is pull start only and has a rotax engine. for a gas tank i used a 6 gallon marine tank. it's just held in with bungee cords. it works as a temporary measure but i will weld up an aluminum tank if i ever have a couple free hours. my hard drive died, and a friend is trying to recover my data... if he can, i'll send you a picture of my tank setup. (not allowed to upload that stuff here at work) good luck with the project
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
