Well I finally pulled the frame out of the tub todayI pressured washed both the tub and the frame. I then applied some rust remover on the frame and am letting it dry overnight. I will make some adjustments to the frame tomorrow and then paint it with black rustoleum. I do have one crossbar in the middle of the frame that is bent slightly. It is the same area where I removed the bent axle. I am guessing one of the previous owners must of hit the middle of the AATV against a tree or something. I will try to hammer it out. I am thinking about buying a shop press. Then I could use it to straighten the axle and perhaps that crossbar on the frame. I just don't know if I could get the frame up and positioned correctly. The shop press would have to open on one side to slide the frame inside. Unless there is a way to position it on the outside of the shop press using a steel jig. Does anyone know? Anyway, I am excited to finally have the frame out and cleaned of 30+ years of sand/dirt and lots of grease. The bearings I ordered are being delivered on Tuesday as well as the flange plates. With luck I hope to have the frame back together by next weekend and then I can start on the transmission. Let me know if someone has experience with a shop press and know of a way to lift the frame into a position so I can straighten the middle crossbar. Pictures attached...
Al
