I am having issues it will run good for about a minute then die like its not gettting fuel. i took the carb apart cleaned everything . then it runs awsome again then dies . could it be the fuel pump isnt sucking enough fuel? anyone else have this problem?
I have a 05 avenger. Did the same thing to me. I had a bit of water in the fuel. Put some gasline antifreeze with water remover in it into the tank, and changed the fuel filter. Fixed the problem.
either way I would change the fuel filter and/or try to run it without the gas cap on, just incase the cap is plugged
