Just got my first 6x6 hustler running,are you supposed to steer as well backwards as going forward? Mine steers great forward but not really in reverse.do I need to adjust transmission
any pointers would be great.
When in reverse, you should pull back on both levers completely to go backwards and to steer push the stick forward on the side that you want to brake. It should steer the same in forward and reverse but sometimes in reverse it is easy to forget to pull one stick all the way back while pushing the other all the way forward. When you just partially push it forward and pull back on the other one that is when it will act like it doesnt want to steer. Just really make sure you are pushing / pulling the sticks completely.
Cool man thanks,all the help is greatly appreciated. I'm still learning a ton about my hustler,it has be difficult to try and finish a project someone else started and didn't complete. Getting excited though can see the light at the end of the tunnel now.
