Outfitting my max
Results 1 to 7 of 7
Thread: Outfitting my max
    Dec 2011
    Mississippi
    214
    Outfitting my max
    Ok guys I have a max 2 need to no will the kt 189 tires fit on my machine they are 24x10x8
    Quote Originally Posted by swamp donkey View Post
    They will.....there are a few members that are running them on their Max II's. I believe they'll clear, but some members, just to ensure the tires didn't rub through the tub, heated the tub and slightly remolded it up. This seems to be pretty simple to do. Just be careful, because the short wheelbase, higher center of gravity, and very soft sidewall of the tire can make your Max less stable, especially at higher speeds, sharp turns, and on hills.
    Savannah, Georgia
    1,821
    As JP said several forum memebers have done this- I would advise you to buy them from a dealer with a large stock of tires and buy the smallest set he has (the tires differ in height and diameter). I would heat the tub to make sure I had proper clearance. These tires swim very well on a MaxII and are great in swamp conditions. Your machine should be just about unstoppable with these tires and I would say you should be able to out perform other machines in most conditions about 85% of the time.
    Good luck, I hope I get to see your machine in action one day
    Dec 2011
    Mississippi
    214
    Have the 21" rawhides on her now hoping to get a little more ground clearance
    Texas
    2,161
    The Max2 is a very capable machine, the small tires are the only detriment. Your machine will be vastly improved with the bigger shoes. In fact, a properly equipped Max2 is one of the best all around amphibs out there.
    Nov 2007
    East Bethel, Minnesota
    104
    what brand is the kt 189 ? I looked around and can't find that tire. did you put them on ? and where did you get them ? wanting to put 24 or 25 on my maxll. do you have pic of them your buggy.
    thanks Mike
    Dec 2011
    Mississippi
    214
    Havnt put them on yet but vie measured them and they will fit without any modifications. There made by carlile
