Hi all - I'm trying to find the output RPM of the T-20 at typical max speed. I have a max II with 18 hp - I know that the RPM will vary based on the throttle I give it but here is why I'm asking - I am working on a dual propeller option that will be driven from the rear sprockets - axles. I can see that all the wheel axles are connected to center sprocket and the center sprocket is connected to the T-20 output shaft. I will share my very simple idea to add a prop for the left and a prop for the right side. I have seen all the posts on this site where this has been done but it seems out of reach for the typical weekend warrior - so I'm gonna make it EZ - I hope
( This site is awesome by the way and it has helped me rebuild everything on this Max II - engine to tranny to bearings - thank you )
SO back to my question .... What is the typical speed of the axles or sprockets or T-20 output shaft or even the tires themselves?? I'm not asking for surface FPM but RPM - this should not change from the tires to the sprockets to the T-20 output shaft. ( Unless the sprockets were different size and mine are all the same. Any help would be greatly appreciated. I may try to measure it but was hoping some one had an idea ?? Thanks
