Is there anything special about the headlights on an Attex or are they just a standard 5inch bulb? I would like to put some back in.
They're just a standard 5" bulb, but I believe the original ones were 18 Watt or so? I don't think you can find those anymore, so I think most folks use 35 Watt ones and they'll work.
JP's right. Unless you can find some NOS bulbs, you probably won't be able to find 18w bulbs. Tractor supply houses usually have 5 inch 35w work lights that fit and work fine, but use a little more juice. Good luck.
Thanks guys.
