Fuel Problem maybe more.
Results 1 to 10 of 12
Thread: Fuel Problem maybe more.
    Jul 2011
    NE
    27
    Ok Here is the problem. I replaced the old Chaparral 484cc engine with one that came from a snowmobile. 1st problem was the replacement engine had the clutch shaft on the wrong side. rather than tear into the newer replacement engine to fix the old one. I decided to just install the new engine in backwards. so now the exhaust is in the rear instead of the carb. and carb now in front. The Problem is the new engine starts as long as you spray fuel in it. but dies. if you keep spraying fuel in the carb it keeps running. had a 20 to 1 oil mix thought that was it but nope went to 32 to 1 maybe 40 to mix still same issue. The Fuel pump has two bottom line one top the top feeds the carb, the bottom two the right comes from engine the left from fuel tank and is mounted on rear drivers side back wall. 1st question being are the lines connected properly which I think they are or the old engine would have never started and ran which it did it just blew the head off from stripped head bolds after rebuild of last owner. that all said i know the carb worked properly before and the fuel pump but just in case i opened them both up made sure they were clean and fresh gas it had been stored with no gas in it I had drained it before I stored it. So i am wondering the clear plastic in the fuel pump seems a little bit wrinkled. my line to the carb now instead of just a few inches away is now over a foot away. Am I looking at a line to long issue and its not pumping fuel to the carb? Or am i looking at a Fuel pump issue which means it needs rebuilt or replaced which I'd do both replace with new and get the gasket kit and rebuild the old for backup. I am thinking its both the line to far away now and faulty fuel pump problem both any thoughts would be welcome. It also stinks i had to flit the engine in backwards and re-route both carb & filter as well as exhaust, which exhaust kind of worries me because i am thinking it may create to much heat and be to close to plastic body. any ideas there would be helpful to. thank you all as always you folks are all always helpful and kind.
    Sep 2012
    Hanover,PA
    1,012
    OK this is tuff with out seeing it but lets try. First off the one line on the fuel pump is the Sence line or Pulse line . It go's to the crank case and that line should be Short as you can get it. ( better pump pulse)
    Second: You may have a Bad Crank seal ! This will keep it from pulling fuel through the motor To check this you see if the crank case hold vacume .
    Good luck and keep us informed.
    5,055
    It's a shame you went through all that custom work, on most 2 strokes the jugs can be spun 180 degrees. Check for vacuum leaks as mentioned above, silly question, is your fuel valve on? Also is this an axial fan engine or free air engine (no fan built in )?
    Sep 2012
    Hanover,PA
    1,012
    X2 ! Jim is rite on this as 90% of the two stroke motors can have there Jug's spun !
    i DID IT ALOT ON THE YAMAHA kt100's for racing karts.
    Northern VA
    2,766
    You may find that you'll have to turn the piston 180 degrees on the rod as well, to keep the rings intact.
    Jul 2011
    NE
    27
    Thanks Don, we suspected you could turn the jugs just wasn't real sure on that one and wanted to be sure the engine ran before time expired to return it as being defective. Plus i don't have a ring tool right now its on the to get list come payday. Thank you.
    Thanks wedge we suspected the jugs could be turned its been over 35 yrs that I worked on 2 strokes and I had thought they could be turned and figured being the chaparral engine was used in so many things it just seemed logical to me that everything they ran these engines in would not have the clutch on the same side and the only way to have a quick cheaper resolve to that would be to make the jugs with the ability to be turned 180 or manifolds reversible and given the blot patterns where different I knew right off the exhaust manifold could not be switched. Which was why I opted to put the engine backwards.
    Quote Originally Posted by Don View Post
    Question being we have custom installed this engine already if we do not turn the jugs and pistons 180 degrees will it harm the engine the way we currently have it configured?
    There don't appear to be any leaks. free air the old engine has a belt air fan on it was going to look to see if it could be attached to this engine just hadn't got that far along yet have been more interested thus far in getting fuel issue resolved so it would stay running.
    Quote Originally Posted by wedge View Post
    What would be the best way to tell and test a bad crack seal and see if it holds vacuum what tools would be needed to test vacuum?
    Last edited by Mike; 08-23-2014 at 04:19 PM. Reason: merged five consecutive posts (you can reply to everyone at once by using the multi-quote button)
    Jul 2011
    NE
    27
    Engine Install
    Just to be sure this is right. It seems logical to turn the jugs 180 degree and in doing so the pistons also need to be turned as well to keep them and the rings protected. That would solve any heat worries from the exhaust maybe melting any of the plastics. and basically the engine would be installed with the same configuration as the old no mods to exhaust pipe or carb. My question then would is there a head bolt order and certain torque on each bolt. i was taught yrs ago when you don't know just start in the center and rotate side to side and just tighten a little tighter than spark plug tight that sound right. check for leaks and good compression which is c currently 120 on both sides, or are there specs to follow I do have a torque wrench just hadn't used or done major engine work in many, many yrs. Being we now know the engine runs an stays running so long as we keep spraying fuel in it, I'd rather the engine be setup as it originally should be. I can make a Suppressor Tool out of a tin can and hose clamp did a few Bikes that way in my younger yrs just gotta be careful of the sharp can and lube well and ease it in the cylinder and back out so I wouldn't have to wait to buy a ring suppressor tool. But still wondered if the current configuration would harm the pistons and rings seems we do have heat issues solved from exhaust and air filter issue solve for carb leaving only getting the fuel issue so I wouldn't have to tear into this engine. Being I now have a drill press and the old engine is out I can install time certs instead of helicoils in the stripped two bolt holes on the head and re-install that original engine back in it. I had done a few motorcycle heads with helicoils one had 4 bolts stripped it worked fine never had a problem with them only had problems with oil cases that had helicoils because they just had shallow holes to begin with and smaller bolt holes and I think only one of them failed and ended up I had to just buy a whole new lower case and tear the bottom end off that engine if I remember right.
    Northern VA
    2,766
    Leaving the jugs and pistons the way they are should be fine. The only thing I wanted to point out was that if you rotate the jug, the piston should be done as well. If you post the make/model of your engine, there is most likely someone on the list that has a manual and can tell you the torque and sequence for tightening: there are a lot of us that have played with two-strokes for a long time
    5,055
    Whoops, looks like I started something.
    To check the fuel pump you could manually pulse the pump with your mouth. Before you do that though disconnect all the lines and blow in each port, 2 should have no resistance and one should have obvious restriction. Also with feed line disconnected if the pump is lower than the tank fuel should run out semi freely.
    Jul 2011
    NE
    27
    Ok its appears to be the Mikuni fuel pump DF44-211 Pulse line is in center on brass barb, the top left barb appears to be from fuel tank and lower right barb to carb. Blowing air into gas tank fuel only came out the the lower right barb so I assumed that was the correct line hook ups. Will take a pic and post it. If I recall right the fuel line from the tank was on the center brass barb I will have to look through the pics I took before I started this. Which even then I am not for sure last owner had the lines connected correctly. The new engine did have loose head bolts and after installing the engine and running it I noticed smoke leaking out so I had to re-tighten again the head bolts tighter than I had before when 1st checking them. I hooked up a small gravity gas tank and it starts and runs, drives and all that just fine. Seems no matter how I hooked up the Pulse fuel pump lines it won't pump fuel to the carb. I even tried a two way barb to double feed the pulse line off both barbs on the block still no fuel. So I'll post pics so I can at least be sure the lines are properly hooked to the fuel pump.
