Flat Tire with Tracks
Results 1 to 9 of 9
Thread: Flat Tire with Tracks
    Pulled my Hytrotrax out to get ready for duck season and noticed I have a flat tire. Hoping some green slime will stop the slow leak, but if I have to replace the tire I am dreading pulling the track pin to pull the tire...getting it on was a pain. Anyone ever pull all three tires and the track together...repair or replace the tire...put full assembly back on?
    Aug 2011
    Central Ohio
    100
    I tried that ONCE, didn't work for me. I ended up sucking all the air out of the tires with a shop vac to re-install them with the tracks.
    Mar 2015
    Pickering, Ontario
    633
    Quote Originally Posted by SlimChance View Post
    My experience was the same. Shop vac is the way to go. Pull the valve cores, vac the tires down onto the rims and stick the valve cap back on to keep your vacuum. Install your tracks and inflate the tires. I start with just the front and rear tires on, fight the tracks on, then I install my middle tire. My tracks are a continuous loop though, I wish I had a fancy hinge pin.
    Sep 2013
    Caldwell, Idaho
    1,175
    Neat idea
    ST400R ATTEX(Smiley)
    500 Super Chief
    This is a great idea...it is only a matter of time before I have to pull a wheel. I have an old shop vac, but no attachments that would fit in the valve stem...did you jury rig something or is there a part I can purchase?
    Ontario-Prince Edward County
    997
    flat tire with tracks
    Quote Originally Posted by Bscout View Post
    I just held the hose end over the valve stem as tightly as I could and the shop vac sucked it flat.
    Mar 2015
    Pickering, Ontario
    633
    I just use a rag to form a better seal around the hose and rim.
    Fairbanks AK
    1,457
    I tapped a piece of 3/8 fuel hose into a small attachement ant it sticks over the stem without holding it. In the field I wrap rope or strap arround the tire and twist it up to crush it. Install the cap until track is back on, then install center tire and inflate.
    Jan 2011
    northern Wisconsin
    892
    I've got this attachment for my shop vac that works great on the valve stem. Not sure where to get it though. The guy I got the machine from gave it to me.
