T-20 shaft bearing lifespan?
Results 1 to 10 of 14
Thread: T-20 shaft bearing lifespan?
    Aug 2011
    Kotzebue, Alaska
    1,209
    Hi, our Max IV needs an overhaul. Its now at 400 hours.
    How long does the output shaft bearings last, generally speaking? Should I trade them out regardless of condition? Thank you
    I can't answer how long they will last but if you are tearing it down for an overhaul anyway, I would go ahead and replace them. It's so easy when you have it apart. If they happened to go out on you after you already rebuilt everything else, you'll be kicking yourself.
    Aug 2011
    Kotzebue, Alaska
    1,209
    Sounds good. I will be ordering bearings then. Thanks Mike.
    Sep 2012
    Hanover,PA
    1,012
    Not being as educated as I would like to be on the T20.(as of yet) But I would think 400 hours is Low for hours for needing bearing already ?
    Unless it was run low on oil ??
    Aug 2011
    Kotzebue, Alaska
    1,209
    We changed trans fluid every 60 hous as recommended. And then again the beginning of summer (the Max was stored away during the winter, only being used during the summer).
    We used 28 ounces of NAPA Type FA fluid mixed with 4 ounce bottle of Equa-Torque.
    The trans was never low on fluid.
    Grand Island NY
    330
    Those bearings should last many more hours. I have well over 1000 hrs on mine without any problems
    Aug 2011
    Kotzebue, Alaska
    1,209
    Thanks for the response. We decided to wait until spring to work on our T-20. Its rather cold out right now, minus twenty and such.
    Any more info is welcome. Thank you all.
    Aug 2011
    Kotzebue, Alaska
    1,209
    Quote Originally Posted by egoperf View Post
    Does this include those small planetary needle bearings inside the case?
    Grand Island NY
    330
    Yes. As long as you are faithful about changing the fluids you'll be fine
    Why are you having to tear down the transmission in the first place? Do you have a band that has failed?
