Hi. I've been reading this forum for a few weeks now and have learned a lot, but I am new to anything with 6 wheels. I recently picked up a used Max IV, and have started to go through it. It seems to drive normally, except the laterals are not even. The left one is a few inches behind the right. That led me to pull the engine and have a closer look at the transmission. It now seems like the uneven-ness is due to slack on the right side (they seem to be "adjusted" to the same position up front where the tie rods connect, but there is slack int he right U channel). Once the slack is taken up they seem to have the same travel- about 6" Anyway, my question has to do with the pictures below. The left side top plunger is much further out of the case than the right. What could this mean? The bottom plungers are about even.
This first one is with the laterals in the normal spring-loaded forward position. I should mention I removed the pin on the left side (right in the picture) to try turning that bolt- it isn't missing.
This one is of them pulled back, I think. I took this picture last week.
I would rather not pull the T20 and split the case if I don't have to. Any advice would be appreciated.
