Originally Posted by
john swenson
dw.. seems that you could probably make your own without needing to weld. if you maybe used a 2'' wide x 3/16'' flat bar metal, cut it the right length ( height of original adjusters ) . drill holes at the bottom to bolt it to the frame where the original adjuster went. then drill and cut a vertical slot at the top to give some adjustment to slide a roller down to keep the chain tight. i bought some roller chain rollers from a co. called black ace with bearings and they have worked great on my max 2. i think they were around $ 30 . get them for a 3/8'' o.d. bolt. then buy the right length bolt to get the roller centered over the chain. use a washer on each side of the roller, the a lock nut . then thru the slot with another lock nut to tighten the bolt after you push it down on the chain. make sure the vertical slot is 3/8'' also. if the rollers are more than you want to spend, you can get a short 11/2'' round piece of white delrin rod from mcmaster carr co. and use that against the chain. it does'nt need to roll ... just bolt it tight to the 2'' flat bar after cutting it maybe 2'' long with a 3/8'' hole in the middle. just a idea for you....... johnboy va.
4
