Max 2 exhaust
Results 1 to 5 of 5
Thread: Max 2 exhaust
    Max 2 exhaust
    Still waiting on my new belt to arrive so I'm lacking a little torque, but today I was attempting to cross a ditch. Traction was good, but machine just didnt have the torque to make it out, that is until the exhaust hose blew loose from the muffler. Immediately after she loudly climbed right out. Just curious if most 6x6 owners keep the stock muffler or throw on an aftermarket muffler? I definitely noticed more power.
    Feb 2016
    Mississippi
    1,108
    you must have a restriction. Even with a stock muffler it should still have plenty of power.
    Jan 2014
    clifton IL
    813
    Dobber I bet you're correct. check your muffler for mud os something blocking the exit! I've had this happen on an attex before
    good luck
    I agree with a restriction in the Exhaust, I just removed my external exhaust and installed a internal one and it is very quite, I wrapped it with header wrap and exited it through the rear. If you have a 18HP briggs then you can also remove the restrictors in the exhaust port with pliers for a little more power
    Does the 16 hp Briggs Vanguard engine have the same exhaust restrictors that can be removed for more hp gains?
    Thanks in advance.
