Hi Guys
Following on from a post I made months ago regarding the joining pins for connecting the track segments. I now have a nice pair of pins with the 90 degree bend and lock nuts on the other end, thanks to Craig B for the recommendation
Anyway, for the Magnum 8 wheel model it is mentioned you require 36 standard segments per side and possibly a half segment.
I’m aware of measuring the circumference and positioning of them and tyre pressures as mentioned in the manual for the tracks
I’ve been told by the local Argo dealer they should only be used with Runamucks, there appears to be no mention of this in the manual.
I have six Runamucks on rims and a full set of tyres that have a more aggressive tread.
Checking the tyre sizes, which I guess is critical, what is the correct size of tyre for this model as the parts manual doesn’t mention this and some of mine are different 22x11x8 and 22x10x8
Also, has anyone used the plastic track with any tyres other than the recommended Runamucks?
As usual all your replies are gratefully received.
Thanks
