So I'm finally doing my final assembly, I think, hopefully at least until it's time for bearings and chains.
I may get myself in the dog house but decided to hell with it I'm buying the red spring, do it nice or do it twice right? Or in this case 3,4,5,6 times fitting stuff and redoing stuff. I'm a fat guy at 350 lbs and was 6'2" before I broke my back. So I'm thinking holding lower gear longer will benefit me greatly, plus when I'm using it for work instead of play. Am I understanding correctly, that it doesn't make it rev higher or anything negative, just hold lower gear longer so I can use more of my power range? My cam is supposed to be good up to 5000 rpm or so, but il be putt-putting alot on trails where low gear will help too. Any down side for a trail machine to have the red spring? Or is it all positive? Thanks to all who helped me along the way to get this thing back in shape.
Hopefully by next weekend everything except my custom seat will be done, for the need stuff at least. Eventually il build a body band winch mount, and I'm sure there will be little tweaks here and there.
