I know this is an odd question, but I just bought a 2006 Avenger. I got it cheap because the guy said it wasn't running right. Upon inspection I discovered that the oil was too full and the plugs were fouled and some foaming in the oil. I reduced the oil to the proper level and it is now running better and the plugs are turning grey. The question is, how smooth are these Kohler twins. The engine does smoke a bit (grey) on choke at cold start. It has a slight bog, again when cold. At speed you can feel the governor working. The engine does thump a bit at idle, kind of like a mild Harley.
Just wondering if this is all normal now as I don't want to drag it in to get looked at....
