Alaska Hustler (aka Sidewinder) 6x6
Results 1 to 10 of 10
Thread: Alaska Hustler (aka Sidewinder) 6x6
    Tracked down a replacement 6x6 unit after selling my Terra Tiger. It has all the amenities that I discovered I needed in a 6x6. Like a quieter 4stroke engine, T-20 skid steer transmission, and electric start
    I'm not sure if the year yet, however this would be a Custom Hustler unit that was sold to Marine Products & Equipment Corporation, where it was modified and rebaged & sold as the Sidewinder unit.
    So far I've replaced the push start switch, got it running and drove it around the yard, where it became apparent there was an issue with the drivers chain drive. Posted on a FB group and got that adjustment resolved fairly easily. (Edit still having some clunky turning effect)
    The 18hp Briggs & Stratton I/C engine, seems sluggish in its throttle response so I looked into the carburetor and found a rats nest of "making it work" if you could call it that. The governor was disconnected and set to a fixed position via spring and the linkage was tied directly to the throttle link lever, not how I believe it should be. I'll be doing more research before moving forward.
    Took quite a few hours today to rejuvenate the upper plastic tub with a heat gun. Turned out much nicer!
    Running pretty good now the carb linkage has been fixed. Off to get a air filter and then a test drive around the block.
    Took it out for a spin yesterday and although it's running better with the governor&linkage more in tune with what it's supposed to be like, it started dieing under load and still rather guttless in drive. Unless I floor the throttle and remove the load to keep it from dying Or ease into the load slowly.
    Tore back into it and discovered 1 cyl not getting random spark, basically only running off one side.
    I'll be replacing the coil first after finding a MacGyver patch on a broken wire.Noticed a patch in the wire where someone had spiced it with house wire, everything was pretty corroded.
    That's an amazing difference using the heat gun! Well done. Overall the machine looks to be in pretty good shape. Nice find. My Hustler had a bone stock un-molested 18hp IC in it. If you need any photo's of the throttle/governor setup let me know.
    Photos would definitely help!
    I have compiled a list of part numbers Im hunting for on eBay, for now it's more or less functioning as intended but I'm working to get it back to stock.
    A length for the rod going from the governor to the throttle would be most helpful, it seems that parts discontinued.
    Here's the stock set up.
    The rods and spring.
    Hope that helps.
    Excellent! Thank you for the references! Definitely be putting it to use
    Got it buttoned up and took it on the voyage travel across the street into the woods and back again.
    Working pretty darn well.
    Did lots updates, taillights, keyed ignition, made a new harness, foam seats, painted the engine and replaced the ignition coil.
    Before next hunting season (because I'm working this season) I'll be adding a winch, beefing up the hitch and turning it's winter cover into a all weather trail cover.
    But for now, it's done. Until I get a hankering to do more 😅
    2,632
    nice job ! ... i appreciate the work you put into it . is your throttle easy to work ? my 21 hp vanguard sure has alot of resistance against the governor . have gotten a couple of suggestions about addressing that . jboy va
    Throttle works pretty well. Have a light tension spring pulling against the throttle cable.
    Haven't had much experience with governors so I can't really input on that, sorry.
Tags for this Thread
