I have a st400/r trying to find a choke cable to fit it the old one is 10.5 feet long. Does anyone know were i could get one custom made or even find one?All i can find in premade cables is 8 footers. any help would be helpful>
You may be able to get some nylon tubing or.. and a wire/cable and make your own. I did that once for a throttle to a sand rail. Only I used brake line as the tube.
I did alot of looking for one recently. Finally found a either 9 or 10 footer at Napa. It was an off the shelf item. It fit pretty well, had to route it carefully. I am thinking it must have been 9 foot because I certanly did not have excess. It did fit the dash without modification and looks stock. If you do not have any luck, I saved the package and will get the numbers. Sorry, just don't know where it is right now!
