driven clutch removal
Results 1 to 5 of 5
Thread: driven clutch removal
    Mar 2008
    Michigan
    41
    Help
    I am trying to remove the driven clutch on my scrambler how does it come off the shaft? is it a shiv type press fitting or is there some special tool I need to get it to move? I have removed the slip fittings from both sides which were held in place by set screws now I need to move the clutch
    There are 3 bolts equally spaced around the clutch on each side that look like they line up but Im not sure if removing them is the thing to do, I dont want to screw up and have a mess trying to put it back togather
    Thankyou for any info
    tlp
    Jan 2008
    Vicksburg, Michigan
    3,507
    I think its pressed on. After the locking collars are off I believe they just close tolerance held in place.
    Last edited by LarryW; 04-18-2009 at 09:58 PM. Reason: was thinking drive, not driven
    Central NJ
    1,470
    You don't want to loosen the 3 bolts. The spring is about 6 inches long and you need a fancy rig to get it back together. Larry W is correct The shaft to clutch may have little if any clearance and may need some heat or a press to move it.
    Nov 2008
    apex, NC
    263
    i just took the middle bolt that goes into the shaft out and rented a gear puller from advance auto parts(great service and you get refunded the full amount when you take it back) and pulled it off
    Mar 2008
    Michigan
    41
    Thanks guys
    I did not want to remove the spring bolts and have a mess
    I will give it a try and see
    tlp
