This question is for Hydrotraxx or similar machines that use wheel motors .
-When the hydraulic oil filters need to be replaced , does the system need to be bled?
-What is the proper procedure to use when you do need to bleed the entire hydraulic system?
-Is there a way to get the wheel motors to free wheel in case of an engine failure in the bush and you need to tow the disabled hydraulic machine out?
Thank you
