So, its like this... the wife and I bought an Avenger 8x8 with 75 hours on it. Its a very nice machine, in very good condition. All for $6000.00.
When we went to give it a ride it always wants to turn left a lot, such that I'd have to give it constant intermittent right adjustments. It also blows hot air from the engine. I heard these things blow cooling air to the disc brakes to cool them. Yet the discs are hot.
After about ten minutes of driving this way the Avenger quit turning left all together. I checked the transmission fluid level. I seen two marks on the trans dipstick, so I added Automatic Transmission fluid for cars, for a lack of knowledge as to what to use. It didn't take much, maybe half a quart.
After the engine cooled down we drove it home before it locked up again.
What trans fluid should I use?
Regarding the two marks on the dipstick, do I fill it between these marks? My Rancher is like this, but I better ask.
Is the heat causing the turning to "lock up"?
How do I solve this issue?
What can I do to correct the steering issue?
Also, the steering "T" handle has a bit of play in it. Is this normal?
Thank you all very much.
