Hi everyone...first post for me.
I have a 04 bigfoot which the previous owner enlarged the rear drain holes by drilling out a similar diameter hole below and adjoining to the existing drainhole so now the hole is more of an elongated shape.
I'd like to fill the drilled hole so I can install the drainplugs and use the argo in the water.
Any suggestions what would work best?
I've ordered the TAP Plastics polyweld product and thought I could glue a piece of hdpe over the entire hole and then drill out a 5/8 hole for the plug.
Or I was considering using a plastic welder to fill the holes completely with hdpe and then drillout the drain hole in the welded material.
Any other suggestions would be mightly appreciated.
Here's a pic of the holes...sorry it's kinda hard to interpret.
