Hi, I have an avenger 2005. The rear chains seems very loose. They almos tought each other with the tensioner almost at the top. When I put 1/2 link they get very tight. Can I leave them tight and they will lenghten and be ok. I always use my argo on low gear. Never go fast. I don't have tracks ( unfortunately). So like they are there too loose and 1/2 link too tight.
Thank you for your help.
if I am to lazy or cash strapped to replace both the sprocket and chain at what appears to be the end of their usable life I half link it,call it done and chances are a bearing or outer seal will come up and then when I pull axles I will change up everything.
so rule of thumb is do what you need too now do what you should do when the urge takes hold,and good to hear from you Doc need someone to double check my thought process after all Iam approaching geezerhood.LMAO Cheers NCT
