Efi engine indicator
  • Efi engine indicator
    Hi- I have 2008 Avenger EFI. Every now and then the EFI engine indicator light comes on for a few seconds and then goes off. This mostly happens when I have it in neutral idling.
    Does any one know if this is something I should be worried at?
    Thanks for any info!
    Turn your key on and off three times, leaving it on the third time. This will activate your fault code diagnostics. Watch the engine light, it will give you two sets of blinks, example (*** Short Pause **, the first set = 3 and the second set = 2) this is a fault code 32. Keep in mind that the ECU may display more than one code, there is a Long Pause between codes. You should always see a code 61 at the end, this in normal
    Some common codes are: 31, 32, 33, 34 = Fuel mixture or Oxygen Sensor and are the most common.
