I was wondering if I could put a different tires size on my argo response 8x8. Size on it now is 22x10-8 to 21x11.00-8 thanks
alternate size tires for argo 8x8
I'm not 100% sure I fully understand what you are asking. Are you wanting to go from 22" tires to the 21" tires that are slightly wider? If so, that shouldn't be a problem for you. If you are asking if larger tires would fit, the largest you can get on your Response / Conquest is certain types of 24" tires that actually measure a little less than 24". Search the site for more info. Here's one thread to get you started: http://www.6x6world.com/forums/argo-...-vanguard.html
You can get John Deere Gator wheels in 10" diameter. I believe they're 9" or 10" wide, so they'd work perfect for you. And they're the correct AATV bolt pattern with 5 lugs by 4.5". Just make sure the ones you buy are the correct offset, meaning the face isn't set too far back in the wheel or too far forward in it. The difficult part would be finding 8 of them. I saw 4 of them come up on ebay cheap a few months back, so they are out there."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
