I have a new Argo 6x6 and this spring plan to add a boat motor. I would like to hear from anyone regarding what motor might be my best choice. My needs are to navigate river and creek currents. The Argo simply needs a little boost to move me up stream. Do I want a gas engine or electric? And what kind of HP or boost should I look for. Thanks, Wilburjohn
Boat motor
You have to be careful not to drain your battery with the electric motor. Some engines do not put out much of a charge....just enough to keep battery charged and run a couple lights....Sometimes if you are using your winch a lot it can drain the battery.
Positive to a gas engine.....If you have gas in your argo then you have gas for your motor...
—Will Rogers
I have a 2010 Max II with a 16 h.p. briggs and the 21 inch tires. Have tryed a 30 lb thrust electric trolling motor and changed the prop to give more thrust,and it is alittle better than the tires, I also have found that an electric trolling motor will draw an amp for every pound of thrust you have, also have a 2.5 horse power 4 stroke yahama short shaft motor and it has also had a prop change to give it the most thrust and it is better than the tires, but it all depends on how fast the river is flowing that you are trying to cross. In spots where i go the river can move the machine at about 8 to 9 miles an hour. Was looking into a 9.9 or smaller outboard because of the weight of the motor.
My 2.5 is about 40 lbs and the 9.9 is about 90 and a 6 is about 60, I run the electric straight of the battery and leave the motor running so if the battery gets run down it is still running when i get to land I can still get out. An additional battery will weight 15 to 28 lbs, motor another 20 lbs so you are close to the weight of the 2.5. I tried to find out about the conversion between the thrust and hp but was not able to find anyone who knew a formula to do that.
I have a 9.9 4 stroke on a 2011 Avenger and it worked great on the 2006 Avenger also. With the 6 wheel vehicle i would lean more to a 5hp 2 stroke. They are light and will push very well in the water. Even with a 9.9 there is only so much speed that you can get due to wheels, hull design and so on and so on. You will need to get a long shaft motor, the short shaft will not reach down far enough to prevent cavitation.
I have a Nissan 5 hp 4 cycle long shaft on my 2006 Avenger, it moves along at a moderate clip, certainly much better than tires, especially if there is a current or wind.
First Nissan or 4 cycle outboard I have ever owned, impressed with power and light weight. Plus the external tank acts as my emergency back up supply of gas for the Argo (not needed yet).
