Was checking the trans fluid,,like none on the stick,,see some dampness on the trans case around the right side Rotor(not on the rotor),,looks like gear lube is oozing out of the 2 upper bearing's,,there is no "Plug Plate" on either of the 2 bearing's,,it looks like they fell out,,theres a "Plug Plate" on the drive belt side,(not leaking),,but none on the right or opposite side,,,suppose to be 2 of them,(leaking now),#23 on the Bigfoot Parts Manual -1.0 Transmission.
I did add 75w90 gear lube to the trans,,but wondering how these 2 "plug Plates" would just be missing ???? Any Ideas ?
I did find a thin sliver of steel on each of the 2 Plug Plate mounting Hole's like something, shaved this sliver off of the Plug Plates,,that are not even there,,,not Good!
