Hi, my avenger bouces so much that even at very slow speed I have to stop because it bouces too much. I have 4 bear claws ( 6 ply), 2 rawhide 111 ( 2 ply) and 2 s2wamper lite. They are all at 4psi. Could that be the reason for bouncing that much. Should I place my tires at different location. at the moment I have the 4 bear claw in front and rear. Should I put more air in some and less in others.
argo bouncing
I run 24" Frontier Tires on my machine, set at 3.5 PSI. If I let the machine sit for a while (weeks), then the tires get flat spots on them. When I take it for a ride after leaving it like that, then I really get a bouncy ride for about a half hour, then the tires seem to get "round" again. May not be what you're experiencing, but with low tire pressures, it just might.
I would think the 6 ply would be very stiff in any position but 3rd and 4th would probably help ride some. i ride my 22 rawhide3's at 1.5 psi but don't think you can go much below 2.5 on the 25's and keep them seated. maybe try 3 in all and see how that feels.sigpic
If they are all at 4 psi, try measuring the circumference of them... You may have a slightly taller tire in one spot and that could be doing it.. I know when my tracks are on, my tires are at 3, 4, 4, and 5 from front to back to keep the measurements correct...
Check out page 35 in this manual this may help you!
I personally, would never run different tires on my AATV. Even though the tires are advertised to be the same size such as 22x11x8 for example, they are actually each a bit different. I'd get all the same size tire and run them all at the same PSI and you'll probably have your issue solved."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
