18" rubber tracks
  • 18" rubber tracks
    My 8x8 argo now has 18" rubber tracks installed and I'm wondering what is the right tire pressure for all tires
    Thanks in advance
    According to ODG(Ontario Drive & Gear) 5psi in the front tires, 7psi in the middle two tires and 6psi in the rears. Did you measure all your tires diameters at 5psi? All your tires diameters will not be the same and the smaller diameter tires should be in front then next size up should be in the rear. Search through the threads/posts under tires and tracks to find discussion on proper placement of your tires when using the 18" rubber tracks.
      Argo 18" Rubber track instructions
      mooselegs72 try this link and look under track kits for directions https://www.argoadventure.com/Argo_A...y_Manuals.html
        Originally posted by akranger72 View Post
        mooselegs72 try this link and look under track kits for directions Argo Accessory Installation Manuals
        Wow that is an awesome site. It should be a sticky somewhere!
        09' ARGO Avenger 750 EFI
        With near every option Argo makes
        and a few they don't
          Akranger is right out of the book. Tires must be sized at 5psi and placed where he said. If you have the stock Argo wheel spacers and stud extensions I've started torquing lug nuts to 70 -75 foot lbs. I've found the manual is 55 but some wheels don't have the dimple pulled tight against the adapter at 55 lbs. been having less trouble with lugnuts working loose since. If the track is slapping under body you can add 1 psi front and rear to stop it. Have fun out there
